gotta question
Discussion in 'Parts Interchange' started by mrfixit1377, May 30, 2008.
  1. mrfixit1377
    mrfixit1377 New Member
    rustburg,va
    74 4 door
    will a 300 i6 mount in place of a 200 with the same mounts
  2. Mavman72
    Nope.The 300 is dimensionally larger.Taller/Longer.my understanding is if you try hard enough you can get one in there but its just not easey or cheap.
  3. newtoford
    newtoford Member
    New Castle Delaware
    not even close
    a 302 would be an easier swap
  4. leov5
    leov5 New Member
    huntington park, ca
    Back in the 80's. When I worked at NAPA, their was this guy who put a 300 in his maverick and was running low 10's in the 1/4 mile. Really rough looking but it would lay down the rubber like forever.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Someone had said they use the same mounts... just heresay.
    I don't know for sure.
    I have seen plenty of pics of the 300 in Mavs. They are very long, and all I have seen required a hood scoop offset to one side of the hood to clear carburation.
  6. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    fordsix.com would be your best bet for info on that(y)
