Hard start only when hot
Discussion in 'Technical' started by Chadwick powers, Sep 30, 2015.
  1. Chadwick powers
    Chadwick powers Keeping it old school
    ca
    1974 ford maverick
    Ok my maverick just start doing this it starts up perfect when cold but when it warms up an i stop for more than 10 mins an she cranks for about 5 seconds an starts up what could it be?
  2. Chadwick powers
    ca
    1974 ford maverick
    Already check it she only does it after she harms up but let her cool off for hour she starts up perfect agian!
  3. rthomas771
    Use a vacuum gauge to tune with...not timing light
  4. 71Mavrk
    71Mavrk Member
    Nevada
    Is it a six cylinder? If you open the hood, do you smell gas?
    If so, it may be heat soak which causes the fuel in the carb to boil off. The fuel pump has to refill the carb before it will start. My car use to do this all the time. Some people have made a heat shield over the exhaust. I just lived with it.
    Micah
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I had the same problem with the 302. I picked up a composite carb spacer from Summit to insulate the carb from the intake, and it solved the problem.
  6. Chadwick powers
    ca
    1974 ford maverick
    Its 302 no gas smell I think its vapor lock cause starts one first hit when colded off
  7. Chadwick powers
    ca
    1974 ford maverick
    I already have spacer on it an I'm touch the hood already with air cleaner
  8. Chadwick powers
    ca
    1974 ford maverick
    What numbers am I looking for on vacuum gauge?
  9. rthomas771
  10. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I have been a mechanic and now part time mechanic for 50 years. worked on heavy equipment for 30 yrs. this is the best article on how to use a vacuum gauge I have ever saw. Thanks for posting this.
  11. Krazy Comet
    Dismal Swamp
    How is tuning with a vac gauge vs timing light going to cure a hot start issue?? Generally that's a carb problem, float too high, leaking power valve, or maybe a slightly leaking needle valve that allows fuel level rise during heat soak... All these can create a flooded condition, which probably 95% of the time is the root of a hot start issue...
    Crazy Larry likes this.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    'Sounds like the fuel is boiling in the float bowl and causing a flooding condition which results in having to crank the starter for a longer than usual period of time before the engine starts. Today's gasoline has a lower boiling point than gasoline from decades ago because of ethanol. If this problem started recently, I wonder if your last fill-up was with E-85 or something.
  13. Chadwick powers
    ca
    1974 ford maverick
    Nope I didn't. Put e85 in it
  14. jasonwthompson
    Carrollton TX
    Is your carb spacer plastic, composite, aluminum?
  15. Chadwick powers
    ca
    1974 ford maverick
