Having trouble with floor pans conversation.
Discussion in 'Parts Interchange' started by Maverickmomma, Apr 5, 2016.
  1. Maverickmomma
    Maverickmomma Member
    Carmichaels, PA
    73 Ford Maverick
    I've recently bought floor pans from Melvin's classic Ford parts and the floor pans aren't fitting in properly. Can someone please tell me how you made them work so I can tell the auto body shop.
    Thanks
  2. mercgt73
    mercgt73 Member
  3. Maverickmomma
    Carmichaels, PA
    73 Ford Maverick
    Thanks. I told him that it will need to be modified but liked seeing want you have done. It puts thing into perspective. I guess I'll have to go to the shop and see what he's talking about.
  4. 71gold
    sounds like you need a different body shop...:yup:
    Tannersg1 and RMiller like this.
  5. mojo
    I think u made/make a gud point! If a lot of guys do it in their garage ... a body man should be able to figure it out...
    Tannersg1 likes this.
  6. Mavman72
    Tell em to make a pattern of the patch they need, then transfer it to the floor pan patch section.The rocker side of the mustang floor pan needs to be cut back and a new pinch weld rail bent up on it. Then it drops in...After cutting the toe board section off. Its just easier to do it that way...Yeah, I wouldnt trust a "body/collision" shop that cant figure out how to section in a chunk of floor pan either.
  7. mav man
    mav man Member
    wi
    70mav
    That's exactly what I was thinking. If they can't figure out how to use mustang pans start looking for someone else. They should be able to make their own floor pans from scratch, much less having ones already in front of them.if they can't do that I'd hate to see them work on the outside of the car where you actually see what they did.if it was me I'd start looking elsewhere.
  8. Tannersg1
    Tannersg1 Member
    Classified
    You were able to say what I couldn't bring myself to say!
  9. Tannersg1
    Tannersg1 Member
    Classified
    Its one of the most basic things you can do in fabrication. Hopefully they don't have to replace the inner torque box.......:90:
  10. rthomas771
    What ever you do...don't cut the whole floor pan out or you take a chance of the car folding in the middle. With a uni-body it is best to replace the floor pan 1/4 at a time
    rotorr22 likes this.
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Great advice. Many shops weld in a temporary brace(s) when removing an entire floor pan.
  12. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    I bought a 67 Mustang drivers side pan for my car from National Parts Depot,a friend put it in with minor difficulty.
  13. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    Out of curiosity, what's the average price to have the driver and passenger floor pans replaced? image.jpeg
  14. 71gold
    it's like any other rust repair, you will not know how much is there until you/they cut it out.
  15. Craig Selvey
    I would say if you take it to a shop: $600 to $800 range
