I need NOS
Discussion in 'Technical' started by LoxMan71, Aug 11, 2003.
  1. Darracq
    Darracq Member
    KillerComet
    What does your car run now. A roller cam and Victor jrs will bring that car to life.
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    :D :D Aww I was just messin around ...Anytime I get a chance to use that picture I can`t resist, for some reason it cracks me up every time I see it:p Ya`ll can still say "NAAWWSS" if ya want to !
  3. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    13.93 @ 99.6 mph. i also need a better converter.This TCI thing is crap. Flashes to 2400 thats no were near were i need to be.It results in 2.12 60's (Bogging)The trans is also messed up AGAIN last year i had it in and out 4 times,so i baught another trans had it rebuilt now after 2 months of street driving its flaring and wont go into 3rd when cold and all kinds of stuff.So intsted of heads and cam this winter its gona be a P.A. performance roller C-4.That will cure it for sure.Oh and a nicer converter.Just that should put me in the low 13s.I gotta take advantige of the tires.It will hook.
  4. Maverick Man
    California
    what kind of rear gear are you running? what heads, cam and carb? just wondering.
    if for some reason if you ever buy a converter i'd go with a contental converter! best damn converters i've seen and used! seen... A1, GERs and TCI all fall apart and not last long. just stating what i've seen.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    There is a place in Nashville that will rebuild your converter to your specs.
    I had them do mine and made it a 4500 stahl and I love it>
    It was around $235 plus shipping.
    "PTC"
  6. Killercomet
    Dirtyburg, WV
    1973 comet
    Its a 4:11 gear,not sure what the cam specs are its a winsor cam (firing order) i havent got around to checking the lift with a dial indicator @ the rocker.The carb is a 750 Holley Dual feed.I know i need more gear with the 28 in. tires crossing traps @ 5300 rpm. Way off.But it all takes time i got that but i lack the $$$.Slow and steady.
