I want to upgrade stock carb to ???
Discussion in 'Parts Interchange' started by Comet4me, Dec 28, 2011.
  1. Comet4me
    Comet4me Member
    1975 Comet
    I want to replace my D5DE-CA 1 bbl Carter/Motorcraft Carb w/ electric assist heat choke with a new electric choke style carb. Does anyone have a good recommendation. I've been reading that Autolites may be a good choice over stock units and that the inefficient log manifold design will always been an issue that a carb alone will never solve. But if I buy new, I want to get the best carb choice for a virtually bone stock engine setup. I believe I at least need to stay with a 1 bbl setup but with an upgrade to an electric choke. Where do I go from here?
  2. Comet4me
    Comet4me Member
    1975 Comet
    Wow, too much info to process as I read about carb choices. Some say 2v is better than 1v, others say no. I don't want to replace what's already installed with the same thing if there is a better choice that I can afford. The Vaporizer 1v looks great but expen$ive and you need to change out your distributed. No thanks. Still reading but not inspired yet. Might just go with a pep boys special soon...
  3. Comet4me
    Comet4me Member
    1975 Comet
    For now, my goal is to get as comfortable as possible with the stock six-banger, since I don't have a lot of money to invest right now. I'm thinking that a better-than-factory replacement would be key right now, until I'm able do decide on what direction I wanna go in the future. I'll read that article you sent me, I haven't seen that one yet. Thanks!
  4. jhohlfeld
    jhohlfeld Member
    Lexington KY
    71 Maverick Grabber, Isaac's 76 Maverick
  5. jhohlfeld
    jhohlfeld Member
    Lexington KY
  6. Steven Harris
    Steven Harris Member
    How about an adaptation of off the shelf EFI parts. Anyone done something like that?
  7. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    My head is at the machinist now. My friend milled, bored and welded the head for the direct two barrell mount. I got the mount and followed the instruction from Classic Inlines.
    I am milling, porting and adding large valve to the head. Along with a 274 cam, double roller timing chain and single out headers. The block is bored 30 over with stock parts as far as I know. Should be a good improvement.
    Rick
  8. jhohlfeld
    jhohlfeld Member
    Lexington KY
    Keep me informed as you go, I am thinking of doing this to my 71 Mav With a 200. What engine do yuou have? What partnumber is the head? I have one from I think a 78 or 79 Farmont. it is a D8 part #. Can you send me a copy of the instructions on the milling/boring of the head, I work with a few machinists.
    Later, Joel
  9. jhohlfeld
    jhohlfeld Member
    Lexington KY
    Hi Rick, How is your engine comming? I haven'therd from you in a while.
    Later, Joel:D
