illumination wire
Discussion in 'Audio' started by nysean91, Sep 2, 2013.
  1. nysean91
    nysean91 Member
    1972 ford maverick
    Figured it out. New alpine fully installed and functional. The wire I fried was the cig lighter I found out
  2. simple man
    simple man Member
    Bunnell,Florida
    Glad you got it sorted! The cigar lighter wire is one heavy duty one! I'd check through your harness and make sure no other wires got burnt. The cigar lighter is hot 24-7, so if it contacts another accessory wire, you will have a constant drain on your battery. :)
  3. nysean91
    nysean91 Member
    1972 ford maverick
    Well the wire doesnt work so still possible?
  4. bigdan56
    bigdan56 Member
    Spokane Washington
    04 F150, 2009 suzuki Boulavard m90, 77 maverick
    the only reason it would not have power at it is the fuse is blown in the fuse block if you replace the fuse it could start another meltdown or possible fire
  5. nysean91
    nysean91 Member
    1972 ford maverick
    Goood to kno. The fuse block under driver side has none blown tho. Is there another block
  6. bigdan56
    bigdan56 Member
    Spokane Washington
    no that should be the only block, fuse may be broken at the end. or wire may have burned all the way through were you can not see it
