In line 250 ci valve bolt torque sequence?
Discussion in 'Technical' started by revatoons, Sep 12, 2012.
  1. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    Hi Friends , anybody to know the ford maverick In line 250 ci valve cover bolt torque sequence?
  2. rthomas771
    3-5 ft lbs. Start in the middle and work your way to the ends same as you would an intake
  3. simple man
    simple man Member
    Bunnell,Florida
    I don't know a specific torque, but all I ever use is a nutdriver! If they're too loose, you can always snug them a teense more. If they're too tight you've bent the rocker cover and it will leak like a b-ch! :)
  4. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    My rule of thumb was to tighten them evenly stepping them down. Stop tightening when you see the first signs that the gaskets start to protrude out. Done.
  5. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    Thnaks friends
