I need to replace my starter on 302 C4 157 tooth flexplate/bellhousing . Is there a small diameter starter availiable for more clearance or from another vehicle? If you have any part# please post them , Thanks Richard
I put a powermaster mini-starter on mine, luv it luv it!!!\ It turns 13.5/1 compression and locked out timing at the 38* like a madman!!! I order it from Sumitt, 302, c4, 157 tooth starter.
the late model truck / car 5.0 permanent magnet starters fit you just hafta connect the s wire to the main lug on the starter to make the firewall mounted solenoid do the crankin
