Late Model Arm Rests
Discussion in 'Parts Interchange' started by kukm66, Feb 12, 2005.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    Anyone know if the mid to late arm rests with grab arm will fit earlier model?
    I noticed several holes in the upper forward position of the door skin.
    Also, are the door handles in the same position?
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Those kind of arm rest will only fit mavs and comets from 73-77. They will not fit the 70-72 mavs. The arm rest for 70-72 are simliar to the early mustangs I think. The door handles are the same. I hope this helps.
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Just put some '73-'77 doors on your car and they will fit. You'll also have the benefit of the internal side-impact bars, which were first offered in '73.
    In fact, my idea of the perfect Maverick is a '71 or '72 Grabber with '73 doors...
  4. 71gold
    small world...
    i am doing a '73 to '69.5 swap now on my doors (thanks M.A.V.). i like the small arm rest. i have the early tray, rear panals and back seat.:bouncy: ...frank...
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    you have to modify the early doors, there are no holes in the early door sheetmetal for the grab arm pull.
  6. kukm66
    kukm66 Member
    Phoenix
    Okay, I went to a yard with 7 Mavericks and checked out all of the doors. The door pulls are moved forward and not near the arm rest. Early doors do not have the capability of retrofitting these pulls. The arm rests could be used by drilling a hole where the top fits. The early armrest will fit all doors since the slots were no changed out.
  7. Rhonda0794
    Rhonda0794 Member
    Seattle
    1973 Maverick Gold 4 Door
    Arm Rest
    HI,
    I need some arm rest/handles for the front doors of a 73 Maverick. If it ends up you can not use the ones you have, let me know. Thanks!:yup:
  8. 71gold
    rhonda,
    i will have a set when i do my door swap. the doors are at the paint shop. when i get them back i will let you know...frank... :bouncy:
