late model rearend and brakes
Discussion in 'Parts Interchange' started by JD71, May 12, 2008.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    would the rearend off of a later model mustang fit on my 71 maverick? and what about the disk brakes?
  2. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Im thinking it would be to wide but i dont know exactly
    :hmmm:
  3. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    what if it had different spindles
  4. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    wow i really didnt get a response about this, im now getting around to possibly getting a new rear, any idea what years and models would have rear ends that would bolt right up to the maverick and not be too old and rusty to use?
    also what cars had lower gear ratios
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Try one of the 8.8 rear ends out of the late 90's explorers ,they have disk brakes and they come with ratio's like 3.73 from the factory. They are a little wider than the stock rear end but with the right offset tire it could be bolt in. Look it up on the forums there have been several discussions about these axles.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you have an 8" rear, then all you need is the discs off a Crown Vic 8.8" rear.
    Most of the 8.8" rears have offset diffs, as well as being too wide...
    Therefore cutting, welding, and fabbing will probably be needed. They will not be a bolt in affair.
    The discs though, nearly are a bolt in.
    You would end up with a stronger and lighter rear, while spending the same time and money, by fabbing up a 9" rear.
  7. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    My reason for changing rear is for the rear end ratio. i have the stock 2.79 and i need something lower for the 302 and aod i plan to put in
  8. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Stronger? Yes. Same time and money? Not necessarily.
    I just bought a complete 8.8 rear with disc brakes out of a '96 Explorer for $100 (you can get them at the you pull it lots around for no more $150). It has limited slip, 31-spline axles, and 3.73 gears. I will cut down the left axle to be the same the length as the right axle and buy another right side axle for $90. The only other parts expenditure will spring perches, spring perches, gasket, bearings, and rear end dope. I will have a 3.73 limited rear with newly rebuilt disc brakes, new axle bearings, c-clip eliminators, etc., and about the same length as a Maverick 8 inch for less than $450.
    While you may cut a 9 inch to fit and buy another axle for the same price as I will for my 8.8, the chances of getting the gear you want, posi, and rear disc brakes for the same price is almost non-existent. Unless you're going with more than 450HP, running slicks, and leaving the line hard, the 8.8 rear will serve you very well. IMO.
    Oh, you want one out a '96 and later Explorer and Mountaineer with the 302. Be sure and look at the tag.
  9. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    I'd like to get something that doesn't need much fab at all. i'm thinking about getting something like the front and rear parts to swap from a galaxie or monarch. any idea what that would cost? and what gears did they have
  10. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    It may be cheaper and easier for you to change the gear in current rear end and then add disc brakes. Mavman has a thread on here how to add S-10 brakes to a Ford rear end and 71gold did a write up on putting the brakes off of late model Ford Explorers, Crown Vics, etc. on your current rear end.
    The only rear ends that are a bolt in are the ones of Granadas, Monarchs, and Versailles. Most of those were high gears like the one you have now. If you want a different gear, there is no value in swapping in one of those rear ends unless it is a 9 inch, and then you would still need to change gear.
    Do a search on e-bay for 8 in center sections that have the gears you want and posi unit already added. You may get lucky.
  11. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    Could someone explain limited slip. would i still be able to burn out? and what all parts are in a center section of the rear?
  12. Hawkco
    Rex, Georgia (GA)
    77 Maverick
  13. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    thanks that was good info, and a pretty neat site. is a differential rearend size specific,and would it be something that wouldnt be any good after setting up in a junk yard too long?
  14. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Yes, rear ends are size specific. The wider the car, the longer the housing and the axles. A F150 rear end is going to be too wide for a Maverick. This site gives some of the measurements:
    http://dfwmotorsport.com/Fairlane/9inchrearends.htm
    The ring and pinion of an 8" rear end will not work in an 8.8 inch or 9 inch rear end and vice-versa.
  15. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    On ebay i saw a 3.55 ring and pinion for an 8 in. thats the 2 gears right? will i need anything else to swap over the gears? did they ever put limited slip in the 8 in. does it do anything else besides help When on ice or stuck. not alot of ice in mississippi
