Lincoln Versailles Parts ?
Discussion in 'Parts Interchange' started by 98truck, May 24, 2004.
  1. 98truck
    98truck Member
    london Canada
    1970 Grabber Maverick
    What parts can you use for a 70 Mav, other than rear end.
    How about brake ensembly from a Versailles?
    I'am stripping one and I just like to know what other parts could be useful when restoring my car [​IMG]
  2. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Engine, Trans, wheels, disc brake spindles, bucket seats and console if it has one (the one I stripped actually had a power bench seat!), dome/map light, lighted visors, steering wheel, trunk mat/carpeting.
  3. 98truck
    98truck Member
    london Canada
    This car is totally load & yes it has a floor shifter with a console in it
    How about the sterring colum & the power disk brake cylinder ?
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I could have used the wiring harness for the dome/map lights but my new headliner is already installed ... :(
  5. Sam M.
    Southern NJ
    The steering column and master cylinder/ power booster unfortunately will not interchange with a Maverick. I really wanted a tilt wheel in the Mav but it wasn't to be, at least not from a Versailles.
    Sam :)
  6. Sam M.
    Southern NJ
    DMHines; If you're careful, you can fish a new wire in there for the map lights. You can pull off the flexible edging that runs around the top of the door and gain access underneath the headliner material. I used a piece of aluminum fence wire as a fish and pulled another wire right in there.
    Sam :)
  7. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    if you need to do something with the rest of the car there is a site for us closet granada/monarch/versailles lovers out there.. im sure somone there will buy what you have left
  8. Cabinator
    Cabinator Member
    So Cal
    74 Grabber, 70 Maverick
    the lower ball joints on the versailles ire actuallt larger than a mav or granada, you'll need to change them over on the mav to use the front spindles....
