looking to swap my AC compressor for eliminator bracket??
Discussion in 'Parts Interchange' started by Richard Kuss, Feb 9, 2013.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    I have an 89-93 serp belt drive, & i want to get rid of the extra weight & cancel out my AC compressor since i dont have it hooked up(although it works) what is the prefered eliminator bracket style I should go with?? & where to find it??
  2. Richard Kuss
    Red Bluff Ca
    also curious what is the compressor worth? lol
  3. Bryant
    their are several ways that you can get rid of the ac compressor.
    their is a bracket that you can bolt into where the compressor was that has a pulley on it.
    it looks like you dont have a power steering pump. you can completely remove the ac brackets and then get creative. ive seen it where someone puts a belt that just goes around the alternator and crank pulley. the belt will just touch some of the water pump pulley. i believe they loosen the water pump pulley bolts then stretch a belt on, then tighten the water pump pulley bolts to apply more tension to the belt.
    you can find a tensioner that goes the opposite direction and rout the belt around that to take up the tension around the water pump.
    march makes a nice bracket and pulley to replace all the ac pulley and brackets.
  4. Richard Kuss
    Red Bluff Ca
    I'm thinking of putting a bracket with pulley to match the custom one that was made where the power steering pump once was. But as far as the tensioner pulley goes I already have one next to the altenator. I'm not sure if I can incorporate a second one lol
  5. Richard Kuss
    Red Bluff Ca
  6. scooper77515
    I used a Ford Racing A/C delete kit which also pulled the power steering pump up where the A/C used to be. Had to use a different sized belt.
  7. Richard Kuss
    Red Bluff Ca
    I found this picture and it seems this is the same setup i, running, and looks like that pulley bolts up directly to my AC bracket i have already. opinions?
    I believe this is the pulley in the picture.
    http://www.summitracing.com/parts/asp-028200
