manual tranny
Discussion in 'Parts Interchange' started by 73rustymav, Jan 27, 2009.
  1. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    my buddys mom just pulled out a 4 speed from her fox and put in a t5. whats so different about that 4 speed and will it work in my 73... i want it for my 5.o swap if it will work. any insight will help.
  2. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    what motor was the trans on? how old of a fox?
    brad:)
  3. 73rustymav
    73rustymav Member
    had a 302 i think it was 80 - 85 looks simalar to the t-5 as of the shifter style and location.
  4. bradleygt
    bradleygt Member
    1970 maverick
    id say its a t4 looks just like a t5 but the shifter has three bolts holding it on and no fifth gear not as strong I'm sure it will work in a stock type motor
    brad:)
  5. 73rustymav
    73rustymav Member
    sad to say this ive never heard of a t4... could it stand up to mild track and some bat outa hell driving?
  6. bradleygt
    bradleygt Member
    1970 maverick
    define mild track use? had one in a 1979 mustang carbed turbo 4cyl it worked good but the shifter sucked it ran 14.80s burning the clutch all the time then i swapped in a t5 bolted up with no mods at all you can brake a cannon ball in a sand box if you "beat it like a bat out of hell" butt i think it will work if you don't have to much grunt in the bay
    brad:)
  7. 73rustymav
    73rustymav Member
    is a 5.0 ho efi bored 30 over with explorer heads to much:16suspect. i just want to go to the track twice a month and play with the other boys and their hondas.:rolleyes:
  8. bradleygt
    bradleygt Member
    1970 maverick
    you probly will brake it but it mite hold up if you run street tires and be like a old lady when shifting
    brad:)
  9. Ed Schuhrke
    Ed Schuhrke Member
    Lowell Indiana
    1972 Maverick Grabber w/ 357 W, 4sp. Toploader, 9" zoom 4:11 9" N-case DL POSI, Ladders, Welds 15x3.5 - 15x10 w/ Mickey SS, Electric Royal Blue w/ Black grabber stripe, 5" snorkel on original grabber hood
    Its the crappy trans with the internal linkage! why are you calling it by its platform name? we know its either a Capri or a Mustang!
  10. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    I had a buddy with a '82 Capri with a 302 and a 4 speed, probably the same trans.
  11. radmav76
    radmav76 Member
    Toledo, Ohio
    1976 maverick soon to be 460 powered...project on hold.
    The fox 4 speeds are junk....not worth it ....IMO!
  12. Ed Schuhrke
    Ed Schuhrke Member
    Lowell Indiana
    I was thinking it was that German Trans, there was alway trouble with shifter and internal linkage! I use a Toploader.
  13. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Good rule of thumb on Ford 4 speeds:
    Iron trans = good
    Aluminum trans = bad
    That is very general, but true.
