Maverick Toe Panels
Discussion in 'Parts Interchange' started by racerxdag, Jul 10, 2009.
  1. racerxdag
    racerxdag New Member
    Where can I get Right and Left Toe panels or what other car can I use...I DO NOT WANT JUNKYARD stuff. I want new...
  2. 1973Maverick357
    Cookeville TN
    Are you talking about kicker panels?? I don't believe they are reproduced whats wrong with junk yard?
  3. racerxdag
    Toe panels
    Not the plastic Kick panels the sheet metal...I want replacements. Not something junk that I have to work on to much.
    Does any mustang parts work?
  4. 1973Maverick357
    Cookeville TN
    Oh im not sure if they work you could try it but it would probably take alot of work arent they just flat sheet metal?
  5. racerxdag
    Toe Panels
    I believe that steering shaft goes through the drives toe panel.
  6. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Unfortunately no one make Mav sheet metal. Cut outs for a donor car, making your own from sheet metal, or attempting to modifying stang panels are basically the only options. Good luck, lots of people are in the same boat.
    -Corbin
  7. don graham
    Find a good donor car. You can buy a whole car usually for less than parts from a junk yard. Only choice unless you can find some NOS parts on ebay, and I've yet to see those.:)
  8. Mavman72
    You will not find NOS replacement "toe boards" as stated by don and Corbin above is your only bet.Good luck!!!
  9. Dave B
    The steering column goes through a big hole in the firewall, there is a gasket that seals that area, and is repoped...
  10. bmcdaniel
    bmcdaniel Senile Member
    I made mine from 16 ga. steel, easy because that area is flat.
