mustang II front end
Discussion in 'Technical' started by Tomm's '73, Dec 30, 2002.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Thats funny Doug I drove my Mav home from FT Worth in 1990. Maybe they breed well in that Texas sun.:)
  2. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    Tomm:
    Yeah, your only about 90 miles from me! I live about 10 miles east of Austin, in Manor just off of Hwy 290. We'll have to get together!
  3. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    stearing coloum!!!!!
    today I finally got around to the stearing coloum part of my project. Tomm this is another part that you will have to address too,the maverick has no bearing at the base of the coloum because it bolts directly to the box. so what I did was this I used the lower shaft and bearing from the bobcat that donated the front end.....and I also used the piece from the bobcat stearing coloum that took the place of the shift colar. To use the bearing from the bobcat I also had to do away with the shift tube so the bearing would go up in the base of the coloum. when you tear the coloms apart the lower, and upper part of the coloum shafts nock apart and fit perfect!! I will try and take some pictures tomorrow, it will probably help out with what I'm trying to explain.:D
  4. Tomm's '73
    Tomm's '73 Member
    Temple, TX
    72 Grabber,73 Maverick
    Robert, Thanks. I noticed that today and was trying to figure out what to do about it. Hope I can get the major stuff done before I have to leave. Pictures would be great. Got the car level in the back yard today. got to make some measurements and then start cutting the towers out.
    Doug, if I don't have to leave within the next week I'll get in touch and see if I can make a quick trip there.
    Thanks
    Tomm
  5. Tomm's '73
    Tomm's '73 Member
    Temple, TX
    Doug, got some extra parts here from my 73 if you need any (gas tank, front blinker lights, steering gear and other misc. parts) let me know. If anyone else is looking for these let me know.
    Thanks
    Tomm
  6. Tomm's '73
    Tomm's '73 Member
    Temple, TX
    Doug, is there any place there in Austin you can buy the windshield gasket. Checked around here and was quoted a price of 89.95 before taxes, if they could even get it.
    Thanks
    Tomm
  7. gregjsmith
    gregjsmith mavmac
    Albuquerque, NM
    1972 Ford Maverick Sprint
    Sometime back I got a gasket from a for dealer in AZ. Was about $100.
  8. DAB
    Austin, TX
    Windshield gasket
    Daniel Carpenter Repoductions sells them: 800-637-8264
    AutoKrafters.com sells them, too.
