Need help front brake lines 70 mav
Discussion in 'Parts Interchange' started by Jefflee347, Apr 5, 2015.
  1. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    Hopefully someone can help me,. I have a 70 6 cyl Mav with 4 lug drums. I just replace all the drums, shoes, wheel cylinders and master only to find I out my front brake lines are clogged. I can't find them anywhere. Does anyone know if there is an interchange with another car. It has a banjo style fitting on the wheel cylinder side. Any help would be awesome!
  2. tody
    tody Member
    cologne, germany
    steel lines or rubber hoses?
  3. 71gold
    " banjo style fitting on the wheel cylinder side." I would think,...rubber.
  4. Krazy Comet
    Several seem to have this issue and I've never heard of a source for the lines, apparently are unique to '70 Maverick...
    The '71 uses the same hose as '67-'71 Fairlane/Torino/Ranchero, etc... Part no C70Z-2078-A (both R&L)
    What I'm guessing is you may have to swap to later wheel cylinders and use that hose... I don't know if those hoses have the same fitting on chassis end as the '70...
    Mac's has this hose, check link for pict...
    http://www.macsautoparts.com/ford_f...akes-left-or-right-14-1-4-long-1967-1971.html
  5. rthomas771
    The front hoses for a 71-73 Mustang w/disc brakes will fit. You will need to used a 3/8"-24 male to 7/16"-24 female adapter fitting between the wheel cylinder and hose.
  6. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    I will look into this
  7. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    This is what I am working with. I am gonna go to a mustang salvage yard here in Orange County, Ca to see if anything looks similar
  8. Paul Masson
    1971 Grabber
  9. Acornridgeman
    Wisconsin
    Jeff, any number of brake hose shops can take your old hose and make a new one reusing your old fittings. Your picture is a LH hose - the one on ebay as Paul said is a RH one. They are not interchangeable.
    google vintage car brake hose repair - you will find a number of places that do the work.
    Craig Selvey likes this.
  10. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    I'll definetly look into that! I'll let you guys know what happens, and yes this one was off the left but I need both sides:/ and $80 plus shipping is really steep!
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    We use Brakequip for brake hose fabrication, they have a dealer locator on their site, look there to find one close to you.
    http://www.brakequip.com/
  12. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    image.jpg Here are the new lines I had made. $55 each!:(
    Acornridgeman likes this.
  13. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    They had to chop off the banjo fittings, the rest is new
  14. Acornridgeman
    Wisconsin
    VERY NICE! - so much safer than trusting a 45 year old hose.
