New camshaft gone...looking for answers
Discussion in 'Technical' started by CACollo, Oct 6, 2003.
  1. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Hi Earl,
    That is actually what i have done in the past for the regular lock nuts. Worked great! The problem i am having with the posi-locks is that i get the nut adjusted correctly, take the socket off to tighten the allen, and then shortly thereafter the nut is out of adjustment again. Ugh! I suppose i could hold the nut with a pair of needlenose or something, and i'm sure there are other methods, but it just seems like a lot of work (is it really worth it?). One of these days i'll get around to it.
  2. Lightning
    Lightning Member
    Saskatchewan ,Canada
    1971 comet GT
    There is a tool that you can make or buy from some place like summit or Jegs . Basically it is a box end wrench with a 90 degree bend right after the box then another bend about 2 or 3 three inches up . A small tube or pipe is welded to the vertical part of the wrench where you can insert the correct Allen wrench ( T handle type is what I use )
    It works by adjusting the gap with one hand and setting the screw with your other hand . I wish I had a digital camera so I could take a picture of it for you . A very useful tool .
  3. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Compcams E-Z valve lash adjustment tool $49.39 at Summit
    wrench and T handle
    Richard:cool:
  4. Lightning
    Lightning Member
    1971 comet GT
    Here is something similar
    Easy to make yourself if you have a welder .
  5. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Cool looking tool!
  6. MustangSix
    MustangSix www.fordsix.com
    Besides the coils, you have to make sure the rocker and pushrod don't bind either. At high lifts it's possible for a rocker to actually run out of clearnace in the slot under the ball.
