new personal best
Discussion in 'Drag Racing' started by spork1o1, Jul 3, 2016.
  1. spork1o1
    spork1o1 Member
    Michigan
    Finished the install of a fresh 347 with just enough time to pull the Mav out of the garage and load it on the trailer, and head to the track. Missed the first TT session by the time I got there. Pulled it off the trailer and put the timing light on it but it was too sunny out and could not see a darn thing. Ended up just advancing the distributor till the idle started to pick up and called it good.
    Previous best was 9.04 at 76.4 mph in the 1/8.
    first TT pas netted a 7.68 at 94.3 mph spinning the slicks through most of 1 gear.
    made it to the 4th round and broke out by .0079 running a 7.5921 at 93.70 on a 7.60 dial
    The last pass was the best pass.
    Wilbur Green and z28th1s like this.
  2. z28th1s
    Lynchburg, VA
    Big improvements over previous best!
    Good runs for first time out!
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    WOW, a 1 1/2 second improvement it massive. Congrats
  4. spork1o1
    spork1o1 Member
    Michigan
    Well, going from a tired 289 to a fresh 347 probably helped a little.
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Running good, enjoy.....
  6. spork1o1
    spork1o1 Member
    Michigan
    Bumped it up again
    RT .038
    1.60 60ft
    4.78. 330ft
    6.92 594ft
    7.4024. 1/8 ET
    94.29 1/8 MPH
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    What's the engine combo? It's making good power with that mph.
  8. spork1o1
    spork1o1 Member
    Michigan
    Just went a 7.32 at 95.89
    347 with AFR 195 cnc ported, RPM Air gap with a 750 vs holley
    Shifting at 6000 hitting the shift light at the stripe in 3rd gear.
    greasemonkey likes this.
  9. greasemonkey
    Sedalia,MO
    With that mph it might go 7.00's. Mine went 7.19 at 92. That's a nice combo.
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    That's moving! My GTO was mid/hi 7s and ran ow 12s high 11s in the quarter.
  11. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Good Job! Glad to see you're having fun with it...that's what it's all about!
  12. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    Nice times on your maverick with 347.. are you running slicks ?? My maverick with 347 is still little slower..60 at 1.68 1/8 7.5 at 91 mph...I have a older set of drag radials
  13. spork1o1
    spork1o1 Member
    Michigan
    28x9.5 MT ET drags 4.10 gears with a toploader 4spd
  14. spork1o1
    spork1o1 Member
    Michigan
    Also the clutch is slipping and the vacuum secondaries are not working correctly
  15. airford1
    airford1 Member
    San Dimas, Ca
    7.68@94mph is getting pretty fast. You know that the hardest thing to do is break 7:00 and stay in the 6:90s. Good job.
