Non Mav Question
Discussion in 'Other Automotive Tech & Talk' started by mavtricks71, Mar 14, 2008.
  1. mavtricks71
    mavtricks71 Member
    I know this isnt Mav related but need some help, i have a 1991 Ranger, i put new "remanufactered" calipers on it, truck wants to pull to the left when i apply the brakes, ive driven it about 10k miles since calipers, still pulls to left...Heres the kicker, the right side wheel drags more than the left....left spins more free...yet it pulls to the left?? any help would be appreciated :tiphat:
  2. blugene
    73 Comet GT, 72 Comet GT, 2008 "Comet" (our boxer)
    Check that you didn't twist the line arround some how... could also be bad caliper.
  3. mavtricks71
    mavtricks71 Member
    yea ill check the line tommorow, im sure the lines ok...but i will double check
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Just checking here, Are both calipers the same or L An Right? When installing make sure the bleeder is at the upper most point of caliper. Rebleed, after as Gene says check line routing, also make sure hose connections are tight.
    Hanging calipers by hose ends will loosen up over time,, always recheck,
    All things stated above,, well ,, lets just say I still have teeth marks on my rear for not double checking
  5. wagesofsin
    wagesofsin Official Lurkologist
    sarasota, florida
    74 challenger , 73 'cuda , 72 challenger , 74 barracuda
    had a '90 bronco ii do the same thing. make sure you have the right caliper and pad assembly on the correct side. ours acted like it was outta balance (slight vibration and pulling) upon braking.
  6. courier11sec
    courier11sec Member
    Tucson, AZ
    Sounds like the right caliper is hanging up or as previously stated, not properly assembled/installed.
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I'm gonna say brake hose......
    Right side is resticted....
    Hence the drag.....
    and the pulling left.....
    good advice so far
