parting out a granada
Discussion in 'Parts Interchange' started by dav, Nov 24, 2013.
  1. dav
    dav Member
    wisconsin
    1970 maverick,tdi jetta,super duty
    I got a Granada for parts, I am keeping the front brakes and spindles, booster, and master cylinder,proptioning valve. also took the rearend. are there any other parts worth saving? it was a 250-6 auto car.
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Does it have a center console?
  3. dav
    dav Member
    wisconsin
    no console. bench seat, column shift. this is a 1980. it has a vintage aftermarket cobra 8 track player if anyone is interested? (y)
  4. mav1970
    Is that a front strut car? I know they changed over to the Fox platform right before they discontinued the Granada for good :)
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    It's an '80, which would not be a Fox platform. It's the same suspension as the '75 Granada. I doubt the rearend would be an 8-inch though. 'Probably the 8.7".
  6. dav
    dav Member
    wisconsin
    correct this is a NON fox platform. but the rear tag says it is the 8"
  7. mav1970
    If the rear end has a back cover bolted to it, it is not an 8" :)
  8. baddad457
    Lots of 1980 Granada's got the drum brake 9". Seen two of these my ownself. This was the last year(and model) for the rear leaf spring Fords in cars.
  9. Krazy Comet
    Fox bodies wore the Granada/Monarch badges for '81 & '82 only...
  10. mav1970
    My own 9 inch disc brake rear came from a Granada Ghia with a 6 cylinder engine - go figure :hmmm:
  11. baddad457
    They were an option in the Granadas and Monarchs. The first one I bought came from a 77 Monarch. And the only one of about six I've bought that had a trac-loc unit.
  12. bartikus
    bartikus Member
    salt lake city, ut
    yeah the 9" i have for my comet came out of a 4 door 1980 302 powered granada. the gear ratio was terrible though. it was a 2.49 or something like that. i ended up swaping out the center section from a 1973 ranchero that had 3.25 in it.
  13. baddad457
    There were only two ratios in the Granada/Versailles/Monarch 9, 2.50 and 2.75
  14. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    250 I6 blocks are getting harder to find. Also if the cylinder head casting starts with D7 or E0 then it would be very desireble to many of the fordsix.com guys. The D7 and later heads have hardened seats and the largest intake log volume. If I were close I would buy that motor from you.
  15. mav1970
    2.50 was the killer ratio my 9 inch came with - now built with a 3.89 gear set and a traction loc :dance:
