Parts from 90 vics
Discussion in 'Parts Interchange' started by jean282, May 18, 2010.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    hi i am going to remove the engine and transmission from my 90 crown victoria. Anything else can be used on comet ? thank you
  2. maverick75
    I was going to say the rear end, but you have a 73 so it should have the 8" and your set to go :thumbs2:
  3. Jamie Miles
    Trunk latch can be modified to fit your car, so you can pop the trunk open remotely without the key. That's about all I can think of.
  4. maverick75
    and here's the write up :bouncy:
    http://mmb.maverick.to/showthread.php?t=44317
  5. wyliedx
    wyliedx Member
    Afghanistan
    maverick
    What type of Transmission does it have?
  6. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    i think is AOD
  7. bartikus
    bartikus Member
    salt lake city, ut
    you can use the pullys the alt, water pump, and the crank to give your engine a serpintine belt set up on the cheap. thats what i did.
  8. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    kk i will keep the serpintine belt. Can i use mecanical fuel pump with this engine ?
  9. maverick75
    yes, just need to swap the front cover to one that has the provision for one.
  10. rthomas771
    Gotta bolt a eccentric cam on the cam
