depends,what are you planning to swap?if your parts car is a four door and your ride is a two door,things like the driveshaft,rear glass and i believe the trunk are all different.someone else on the board will know of more specific parts differences.good luck with your project. chuck
Not sure by your last post what your talking about but I believe your looking to use a fender and some interior parts? If so, the fenders will bolt on but there is a notch for the stone guard on the front lower cornor that will need to be filled in. Not a big deal. As far as the interior, the back seat is different as well as the side plastic panels. Again, they will go in but there are some differences. If you use the complete back seat and side panels, it will work better but the problem is the side panel down by the sill will not blend in real well. It will stick out a little. The other main difference is the location of the interior door handles.
