Pinion removal?
Discussion in 'Technical' started by Acedmav75, Dec 10, 2014.
  1. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Im taking apart my differential to rebuild it but cant seem to pull it apart at this point. I removed all the screws holding the case in. Theres some play but im still unable to remove the cover entirely. Do i need to remove this pinion bolt? If so does anyone know what size it is? Thanks
  2. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    Do you have the axels out. If you do it should come out. Its not just a cover its the whole differential stump.
  3. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    axles are still in. Ill go ahead and pull those and hopefully then itll pull out no problem. Thank you!
  4. Krazy Comet
    Krazy Comet Tom Supporting Member
    Appears the copper seal washers are still in place, removing those will help as well(though not as much as removing axles)...
    Paul Masson and doncomfort like this.
  5. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Itll be good to remove them anyways this way i learn and see it all for myself. Thanks a million guys!
  6. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    axles are out and had no other issues pulling it out. Now i think i still have to take it apart to replace some parts inside that pinion bolt though haha oh well. Thanks for the help guys!
  7. 71gold
    you only get one shot at getting it right the first time...:yup:
  8. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    well i did good then! haha now im having trouble removing that pinion bolt ugh!:facepalm:
  9. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Impact should take that right off.
  10. 71gold
    I'm referring to the setting it up when you put it back together...:yup:
  11. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    oh haha well hopefully all is well putting her back together. Im visual and once i take something apart its easy for me to put back. Plus ive been taking pictures along the way as reference just in case.
  12. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    i had to get my friend to help me take that bolt off lol. i held the assembly down while in a vice and he used his weight as leverage to finally get the boly loose. Sucker was in there good!
  13. rthomas771
    '74 Maverick 250 5-Speed.'60 Falcon V8 Toploader 9". '66 Falcon Sports Coupe, '63 Falcon Sports Coupe
    More to it than that. The clearance between the gears has to be on the money or the rearend will be noisy
  14. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Ill research that thanks, any recommendation on to how to get it on the money?
  15. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    A dial indicator, marking compound, and a dial torque wrench. It's not as hard as people make it out to be. Just follow the instructions and double check everything. Getting the crush sleeve to start is the hardest part.
