Proportioning Valve
Discussion in 'Parts Interchange' started by Johng1970, Sep 15, 2015.
  1. Johng1970
    Johng1970 Member
    Freeport, PA
    Will a proportioning valve from a Ford Fairmont work for manual front disc brakes on a Maverick?
  2. 71gold
    if it's fixed it may be sized to the M/C. are you running the same size tires (front/rear) as the Fairmont?
  3. Johng1970
    Johng1970 Member
    Freeport, PA
    No, the tires are not the same but the rims are. 14". The Fairmont is a 6cyl with power brakes, the maverick is 6cyl manual disc brakes
  4. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    When we did the manual drum to disc swap on our 65 Falcon, we used this one...
    http://www.jegs.com/i/JEGS+Performance+Products/555/63020/10002/-1
    it should work with drums or discs.
    After installing, open it all the way up to bleed, then adjust the rear + till the back locks up easily, then adjust back down 1/4 of a turn til it feels right.
    Definitely worth $40
  5. 70GreenMonster
    having trouble uploading pics since site was down for maintenance earlier today.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Either use a late-model Maverick proportioning valve or get an aftermarket one that is adjustable.
    Either way, you'll have to change the size of the brake line fittings.
  7. 70GreenMonster
    Pic posting problem gone.
    Here's the valve we got and you can see the dual chamber master behind it (painted red to match engine)
