PS to MS
Discussion in 'Parts Interchange' started by Kevin67, May 19, 2015.
  1. Kevin67
    Kevin67 Member
    Walled Lake, MI.
    Maverick
    What all do I need to make the switch from power steering to manual steering in my '73 Comet?
  2. Rasit
    Rasit Member
    SE Pennsylvania
    Introduce yourself, use the search function, ask questions. ;)
    I think I read where guys change out the center link with a manual one and get rid of control valve, pump etc. Oh yeah, welcome to the forum!
  3. Bryant
    the pitman arm needs to be changed along with the center link, or you can get and adaptor that replaces the control valve that will work with the power steering center link and pitman arm
  4. Rudydog
    Rudydog Member
    1973 Comet
    Will do and thanks. Steering box swap out too I'm guessing?
  5. tody
    tody Member
    cologne, germany
    steering box can remain in place, just swap the pitman arm. you'll have a different ratio, but it'll be all good.
  6. Rudydog
    Rudydog Member
    1973 Comet
    I searched, where can I get the pitman arm I need or what other vehicle will fit for the manual swap?
  7. Rudydog
    Rudydog Member
    1973 Comet
    And what years?
  8. David Crane
    David Crane Member
    1973 4 door
    I know this thread is old and you have probably already done your swap, but may help someone else. What you need is a control valve eliminator from Rare Parts. Here is the one for the Maverick on Amazon http://amzn.to/1IfmTIE It is a simple install, just a PITA! to get the press fitted studs out. Do yourself a favor and go to O'Reilly and rent the tool that looks like a small C-clamp with a claw on the bottom(Can't remember what it is called, but it is on their poster) and use that to press the power cylinder and ball stud out.
    Also, here is an article on it: http://bit.ly/1Oi49Xj
  9. 71gold
    I used one of them for my 73 Mav and it had as much slop in it as the worn out power steering had.
    I replaced it with a pitman arm and center link from a 70 MS... thanks Mike...:Handshake:
  10. David Crane
    David Crane Member
    1973 4 door
    Yeah, just depends on what is worn. In my case it was the power cylinder and control valve causing it to be erratic, but YMMV
  11. Mav06
    Mav06 Member
    El Paso
    1970 2Dr 200 c.i I6
    I found a 66 mustang with MS will the pitman and centerlink fit a 70 maverick?
  12. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Nope.
    Craig Selvey likes this.
