radiator question
Discussion in 'Parts Interchange' started by ronr11, Apr 7, 2005.
  1. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    is the 77 250 -6 the same as a 302? thanks
  2. 74 maverick guy
    74 maverick guy Member
    oneida newyork
    74 maverick has 250 st.6
    im not posative but i think you can use the 250 radiator with the 302
  3. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    If the 250 had air cond. it will be the same, a 3 row. If it did not it will be a two row. It will physically fit but will not run as cool and could even make it run hot depending on if it is clogged up after years of use. I would always go with a new radiator a 3 row at AutoZone is 170.00. I've had mine 3 years and never had a problem.
  4. 74merc
    74merc computer nerd
    1974 Comet
    dunno about the 250, but I can say for certain the 200 has a different radiator.
    If you can get a parts house to cross reference radiator part numbers between the 200, 250 and 302, you'll have a bit more info.
  5. Craig Selvey
    I believe the 250 radiator has a smaller inlet and outlet as well.....for smaller hoses. The ones I have do.
