Rc motorsports front end installed
Discussion in 'Technical' started by Mlovett, Aug 31, 2013.
  1. blugene
    73 Comet GT, 72 Comet GT, 2008 "Comet" (our boxer)
    Any plans with that front crossmember?
  2. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    Probably going to leave it. I really don't know
  3. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    The bottom A arm is not rounded just the top.
  4. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    Another pic
  5. 71gold
    my top one is straight...
      File size:
      99.7 KB
      59
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    That rounded upper CA looks like it would work with an air bag system, maybe they changed for that reason so they wouldn't have to build two different arms?
  7. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    Yeah I bet that's why they rounded the CA
  8. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    73 new rebuild
    The motor is just setting there with tranny attached
  9. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    73 rebuild
    Another pic
  10. car-nut
    car-nut Glenn
    conn.
    Why did you cut the trans tunnel? My AOD fit without cutting.
  11. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    73 rebuild
    Did u use a 4l80e trans? Mine had to be cut just to set the motor in place not to mention the angle the trans tail housing has to be to get the right pinion angle
  12. car-nut
    car-nut Glenn
    conn.
    No, as I stated I used an AOD. Now I see why you cut it.
  13. 74merc
    74merc computer nerd
    1974 Comet
    Is that an FE?
  14. Mlovett
    Mlovett Member
    Westlake la
    1973 maverick
    No it's an LS1. Chevy motor
  15. 71gold
    no tunnel cutting for my...5.3 700R4 install in my '73.
    I knotched the oil pan so the motor could sit lower.
      File size:
      101.8 KB
      32
      File size:
      87.7 KB
