rear quarters
Discussion in 'Parts Interchange' started by lilfarley, May 25, 2007.
  1. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    I have a 1974 that needs a lot of rear end bodywork, I found a 1975 that I am considering buying to use as a parts car, they are both 2 door. Will the sheet metal be the same? :huh:
  2. Craig Selvey
    If the 1975 is that good...restore the 1975.
  3. lilfarley
    Central City, Iowa
    the 74 is a factory 302 and it was my grandpas car, The 75 is a 6 cyl.
    plus I am going to go check it out tomorrow morning.
  4. Craig Selvey
    It will be sooooooo much easier to take all the good parts off of the 1974 and put them on the 1975 then it would be to cut off and re-weld quarters on a rusty car. Just something to think about.
  5. lilfarley
    Central City, Iowa
    the 74 is not rusty it is just the rear quarter panels that need replaced because it was backed into a light pole on the drivers side so it is crumpled up
  6. Mavaholic
    The sheet metal is the same.
  7. lilfarley
    Central City, Iowa
    thank you for the answer about the sheet metal
  8. Craig Selvey
    Pictures of both cars would help in this discussion.
  9. lilfarley
    Central City, Iowa
    the one i was going to buy was worse than mine and i didn't buy it
  10. newtoford
    newtoford Member
    New Castle Delaware
    i think the rear quarters on any year 2dr maverick or comet are the same.
