Rear vibrations
Discussion in 'Parts Interchange' started by dbheath76, Apr 28, 2011.
  1. dbheath76
    dbheath76 Member
    Uxbridge, Massachusetts
    1976 Ford Maverick
    I'm wondering if anyone can tell me why I"m still getting a vibration in the rear ... I have a 1976 ford Maverick ... I've changed the universal joints, the shocks, and put brand new tires and rims ( also balanced) .. I had the driveshaft balanced also !!! any ideas ??
  2. Bryant
    worn out transmission mount and or motor mounts will cause a drive shaft vibration. also check that you have the right diameter u-joint caps on the u-joint where it seats into the yoke on the diff. they require what is called a big ford 1310 cap.
  3. dbheath76
    dbheath76 Member
    1976 Ford Maverick
    thanx so much Bryant ,... I will let you know what I find ...
  4. scooper77515
    Describe the vibe to us.
    I have been fighting one for years, and found that it was exhaust drone the entire time.
    I have verified this by modifying the exhaust, only to move the rpm range of the drone, but not cancelling it out.
  5. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    low or lack of lube? pinion/axle brng? bent axle? brake drum? went through simular issue on 9in in a f100, had to put the rear up on stands and run it to find bent axle.
    good luck brother
  6. 71gold
    ...tailshaft bushing...:yup:
