Resorting to plan B
Discussion in 'General Maverick/Comet' started by Del Austin, Mar 6, 2013.
  1. Del Austin
    Del Austin Member
    Chandler, AZ
    1970 Maverick & 1974 Maverick
    After striking out repeatedly on locating LDO side trim for the 74 I am thinking of using parts off of the 70 that I had plans to build someday.
    Thinking of removing all of the side trim, side marker lights and emblems from the 74. I will use the doors and fenders off of the 70 as well as the small bumpers. I am thinking of adding a Grabber hood and rear spoiler. The car will be dark metallic blue (close to Acapulco Blue) with a white top (retaining the LDO trim).
    How well do you think it will look with this combination?
  2. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Im sure it will look good, but if you really want the ldo look id stick it out a little longer.
  3. Del Austin
    Del Austin Member
    Chandler, AZ
    Honestly I wasn't much for the LDO look, but ended up falling in love with the car. Just realizing that if I resort to parting out the 70 this may be my one shot at the Maverick that I really want.
  4. Dave B
    I love the LDO trim, it just makes the car stand out from the others.
  5. Del Austin
    Del Austin Member
    Chandler, AZ
    I agree, but if I cannot find the passenger side trim for a 2 door soon I will start with plan B as I don't want the car to just sit unusable in the garage.
    If I can find the trim my plan is to paint the insert white to match the roof as the rubber insert I have has seen better days and is a challenge to keep white. I also thought about cutting the trim (I know) in the insert portion at the very front and rear and put the side marker lights in there ans omit/fill the factory lights. I already have the lights that will fit perfectly in the recess.
    That would be preferred, but if I cannot locate suitable trim...
  6. 71gold
    why would it have to sit without the trim...:huh:
    I have driven mine at different times without...doors, hood, fenders, bumpers, trunk lid and exhaust system...:thumbs2:
  7. Craig Selvey
    Agreed. I drove my 1970 Grabber, after it was painted, without sidemarkers until I found an NOS set. The trim will eventually be found. Keep the trim.
  8. mavmad
    mavmad Member
    Waddell,Arizona
    1974 Comet
    re;side trim
    Hi Del Austin,
    I have LDO trim for the 2 & 4 door car.Has the brown vinyl in it.It's only in 'ok' condition for most pieces.I believe one piece on each car was damaged.Passenger rear on the 2 dr & drivers front on the 4 dr.
    John
  9. Del Austin
    Del Austin Member
    Chandler, AZ
    pm sent!!!!
  10. Paul Masson
    1971 Grabber
  11. predfan2001
    While I do like the early small bumper Mavericks, your looks great with the LDO trim. I'd stick it out and find some trim. Finding parts for these cars gets disgusting at times. I was totally motivated on my car till I found the hood was bad. Trying to find a good hood has held me up and totally taken the wind out of my sails.
  12. Del Austin
    Del Austin Member
    Chandler, AZ
    Looks like I will be converting to small bumpers and swapping out the 250 for a V8. I will be retaining all of the original parts for the car, but after not being able to find a lot of the parts in suitable condition I will be using parts off of my nice 70.
  13. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    I'm picking up a 4 Dr that has the side trim.. If you want it
