right starter for 302?
Discussion in 'Technical' started by Gary Stewart, Dec 2, 2011.
  1. Gary Stewart
    Gary Stewart Member
    north carolina
    74 comet gt
    bought 4 starters for my 74 302 comet...3 speed..nose reach was 3/4 inch short. in the computer were the correct parts,,,i looked at the starter for an automatic..nose reach is 2 1/4 which worked out perfect..any one have this problem?? or does advance and A.Z. have their computer info incorrect???
  2. Dave B
    You are posting a question in the classifieds.....:huh:
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    This is correct.
    Moving this one. please keep an eye on what section you're posting in moving forward.
  4. rayzorsharp
    There are two different length noses with the standard shift having the shortest nose length.
  5. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    That is typical on nearly all FORDS.......very unique:dance::chirp::thumbs2:
  6. bmcdaniel
    bmcdaniel Senile Member
    Yep, found this out the hard way many years ago. Bought a starter at the local parts house, kid behind the counter didn't even look up a part number for my manual trans application. Just grabbed one off the shelf and said "Here's the one you need". He had given me the longer-nosed part for an automatic and it broke about half the teeth off of the flywheel starter ring when I tried to start the car.
  7. Gary Stewart
    Gary Stewart Member
    north carolina
    74 comet gt
    the longer nose starter worked for my application..it was only 3/8 longer.with 3/4 depth left on the starter hole..factory 3 speed and matching #s of body/engine..74 Comet..soooo i dont know the answer to my own question....i cked some of my sons old mustang leftover cores they all had the longer nose..all i know is what works!
  8. bmcdaniel
    Hmmm, I'd have to go look at my spare starters, I have ones for manual and auto trans. Could be i got the long vs. short nose bassackwards. Anywho, the wrong one can cause a lot of grief.
  9. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    jeez..now you guys got me all nervous about starters! i thought it was one choice and done. i wanted to get one of those fancy high cranking ones or whatever to make sure my car starts.
