Should I upgrade to 2 bbl carb??
Discussion in 'Parts Interchange' started by Comet4me, Oct 5, 2014.
  1. Comet4me
    Comet4me Member
    1975 Comet
    I need to replace my carb, which is currently a 1 bbl motorcraft, on my il 250. Is it better to upgrade it to a 2 bbl carb at this point? I know I'll need an adapter plate. Any thoughts?
  2. Craig Selvey
    Unless you are prepared to do other modifications.....I think it will be of any use.
  3. Comet4me
    Comet4me Member
    1975 Comet
    What other mods are needed?
  4. Craig Selvey
    To really take advantage of the bigger carb, you need to change the cam and add an exhaust manifold as well as other mods. that is why most just go to a V-8.
  5. Comet4me
    Comet4me Member
    1975 Comet
    I have a custom ceramicoat true dual exhaust system. No cam though
  6. Craig Selvey
  7. Comet4me
    Comet4me Member
    1975 Comet
    Yes ceramicoat headers and stainless exhaust
  8. Craig Selvey
    You really need to determine what your goals are with this car and engine. Just "adding parts" without a plan can mean a lot of money spent with not much to show for it.
  9. Comet4me
    Comet4me Member
    1975 Comet
    The headers went on because I couldn't find a stock exhaust manifold, and I wanted something less restrictive. And the dual exhaust went on, because I needed a new exhaust because of the addition of the nee headers. I just wondered if the 2bbl carb was a logical upgrade from the 1bbl, since I'll be replacing it anyway. It's just a daily driver, but I was hoping to step it up a bit from stock, that's my current goal.
  10. Krazy Comet
    Basically yes, though the integral intake is a restriction so I dunno how much improvement you can expect... Main problem is if it's over carburated it'll be lazy, maybe bog at low speeds...
  11. rthomas771
    To get your moneys worth...remove head and take it to the machine shop and have them hog out the hole in the log. A 1-to 2 bbl adapter ain't gonna help at all in performance. Only thing the '1-to-2 adapter' is going to do is make you smell gasoline
  12. 71gold
    as suggested, you need the complete package.
    2 bbl.carb...Assie head...cam...header (s)...rear gear.
  13. Comet4me
    Comet4me Member
    1975 Comet
    I guess I'll stick to a 1bbl for now. Any brand recommendation? I have a hear choke if it matters
  14. Craig Selvey
    Rebuild yours....pretty simple job.
  15. Comet4me
    Comet4me Member
    1975 Comet
    It is rebuilt. The fuel bowls are leaking and dumping fuel into the engine. Needs to be replaced.
