Stroke Kit from Summit Racing
Discussion in 'Parts Interchange' started by mave73, May 8, 2011.
  1. mave73
    mave73 New Member
    mexico df
    maverick
  2. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    One has a forged steel crank and higher comp.ratio. The other is a cast crank. The forged is better but it depends on what your doing with the car
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    i'd go with the forged crank kit, and some afr heads to compliment the bottom end
  4. maverick75
    It really depends on what your goal is, the 9000 cast is plenty enough for 600HP which is around the max a Mexican block can be put to.
    They also have a 331 kit that is more affordable.
  5. bmcdaniel
    bmcdaniel Senile Member
    If you're using a production Ford block just run the cast crank, the block will split before you hurt the crank. If you have an aftermarket block step up to the forged internals.
  6. mave73
    mave73 New Member
    mexico df
    maverick
    all right, thanks for your answers. :Handshake
  7. mave73
    mave73 New Member
    mexico df
    maverick
    My block is production 289 ford and I dont know if I have to change it to 302 production? or 289 works?
  8. maverick75
    289 will work, the only difference is the size of the crank/rods....Otherwise its the same thing as a 302.
