T5 cable operated clutch pedal conversion
Discussion in 'Transmissions' started by BBMS18, Feb 24, 2019.
  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Will do.(y)
    I have both fox & SN95 clutch pedals, so the plan is to convert the non-power pedal assembly that’s in the car. Then see if converting the power assembly is a viable option, I don’t want to destroy a power brake assembly if possible.
  2. t.ramsey
    t.ramsey Member
    austin,tx
    both
    Have you done the swap yet? I have a line on some SN95 pedals and want to use them.
  3. BBMS18
    BBMS18 Member
    75 Comet
    No, it’s on the list for this spring. It shouldn’t be a problem, you’ll just be using the pedal and grafting it onto the Maverick/Comet pedal box.
  4. 302proof
    302proof Member
    73 grabber
    Added a sn95 pedal. Used a 1" od 3/4" id x 6" steel bushing. Then used bronze bushings to replace the oem plastic. Used a washer to fill in the remaining gap. Travel is smooth.
    t.ramsey and BBMS18 like this.
  5. t.ramsey
    t.ramsey Member
    austin,tx
    both
    Do the pedals go on each side of the steering column? If so, does the column have to be removed or can they slide around it?
  6. BBMS18
    BBMS18 Member
    75 Comet
    Pedal assembly mounts above column, you may be able to unbolt column and lower it down to remove pedal assembly but IMO remove it and make things easier on yourself.
    t.ramsey likes this.
