i have a questions ,my comet 1971 have a c-4 transmissions and i think change this and instal aod trans,what part i nedd to this changes,transs crossmenber,tv cable,etc,thnaks for a helph
you will need the correct flex plate for your motor, if you are using the 71 motor you need to get a 28 oz balance flexplate that will mate up to the AOD, make sure you dont get the 50 oz flexplate.....
i think the AOD uses a 164 tooth flex plate at least mine did. also their are very finicky make sure you get the cable adjusted right or you will fry the tranny. that what i did to mine . i just modified my tranny cross member but i would recommend buying the one on here so you can change back if you want to.
