Throwing Fan Belts
Discussion in 'Technical' started by Scotty P, Mar 14, 2009.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Besides alignment, can anyone think of a reason my fan belt keeps coming off once I pass 6000rpm ?
    Last weekend it came off, jammed into the space between the balancer and the water pump and SHATTERED the water pump pulley!
    Thanks, Scott
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Are you using the correct width belt?
  3. mean_maverick
    if ur running the correct belt, and it's not too loose.... then the pullies almost have to be out of alignment
  4. Craig Selvey
    Cheap belts will "throw" as well.
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Right size belt, sits down in pulley. I borrowed an alignment light from a neighbor and it lined up well. I have tried several belts but maybe that is the problem. I will try another belt. Txs
  6. Bryant
    good year and gates belts are suspose to be the best thats out there
  7. Blown 5.0
    MS.
    1974 Maverick
    I never had the problem of throwing the belts, Mine would actually BURN the belt in too. I tried many different kinds and the two i found that worked the best were the cheap Napa line, Which they no longer make. The only belt i find now are the Advance TOP COG, They are the only SOLID belts i can find. They work good but have to be tensioned 2 to 3 times before they finally take a set.
  8. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    or have run out in them!!
  9. rayzorsharp
    :idea: I think you're just going too fast. :)
  10. Gent
    Gent Member
    virginia
    72 grabber
    slow down the belt with a smaller crank pulley.
  11. Scotty P
    Scotty P Member
    santa rosa, ca
    You mean a LARGER crank pulley ? I did order a new water pump pulley (since mine is in 2 pieces!) it is pretty old and could have some run out in it. I did not think of that.
  12. Bryant
    smaller will go slower.
  13. blugene
    73 Comet GT, 72 Comet GT, 2008 "Comet" (our boxer)
    No comment :p
    :hmmm:What kinda light are you saying you used? The damper is good? I have run cheapie belts to 7k...
  14. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    Is all the hardware mounts solid the belt runs and has no 'give'.
    At 6000, the belt tries to climb out of the grooves if it slips, gets hot and gets more sticky besides the belt streching enough.
    This can 'spring' the mountings enough to make it once and done and all looks well after the fact.
    Once a belt jumps it usually has permant damage to the cord structure.
  15. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Stop reving to 6k. Your car doesnt seem to like it much.
