Tire selection advice
Discussion in 'Wheels and Tires' started by MountainMav89, Apr 21, 2020.
  1. MountainMav89
    MountainMav89 Member
    West Virginia
    1976 Ford Maverick
    I have a set of Cragar nomad 1's
    15x8 , they have 3-3/4'' backspacing and -19mm offset
    I'm running 3.55 gear ratio.
    I was wondering what size I could go up to on the rear, and also what would be good on the front.
  2. 71gold
    :Welcome:...:Handshake:
    go to ...
    Technical...
    click on...wheels and tires. a lot of talk there.
    MountainMav89 likes this.
  3. Hotrock
    Munroe Falls, Ohio
    That 3 3/4" backspacing isn't going to work out very well. The tires will protrude passed the wheel well lip which will result in tire sidewall gouging. 4 1/4" or 4 1/2" backspacing works best with an 8" wheel.
    You can also review the wheel and tire data in the Garage section of this site.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    3-3/4" will work on the back, but on the front you'll need to keep the tire narrow like a 215 or less. 4-inch is ideal for Mavericks. 4-1/4" will work, but 4-1/2" will rub leaf springs and frame rail.
    With the wheels you currently have, a 215/60-15 will work on the front, and a 245/60-15 on the back...
    BBMS18 and MountainMav89 like this.
  5. MountainMav89
    West Virginia
    1976 Ford Maverick
    Thank you all!
