upper control arms ?weird??
Discussion in 'Parts Interchange' started by Will, Jun 5, 2003.
  1. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    I was pulling the spindles off of a "74" mav and a "74" grabber, and went to switch them out and the passenger side has 4bolt holes while the other car has 3 bolts in the upper arm that keep the upper ball joint in. Was there a change, the grabber's build date is late 73 while the other is in 74, was there a change? :confused:
  2. Mavaholic
    The old Mustangs and others used 4 bolts instead of 3. I believe they changed sometime in 70. I'll bet that upper a frame was changed out sometime in its life. Was both sides 4 bolts?
  3. Will
    Will I
    Waco
    nope, just the passenger side was 4bolts.
  4. BlkWlf1968
    BlkWlf1968 Member
    Arlington,Tx
    1973 Maverick 2dr
    I have found that several early 70's and late 60's cars that share the simular front suspension as the mav use the 2 diffrent styles...My 70 Torino GT had 4 rivets/bolts on both sides...I swaped the upper a-arms to my Mav,which had 3 bolts...it is a diffrent yr/make piece.You might have a hard time when you go to change balljoints,but othere than that they are the same...
  5. Earl Branham
    Lugoff, SC
    Do you have the part# for the original ball joints? The ones I get from the supply houses are smaller, have no provision for zerk fittings, and are 3 bolt. Any help would be appreciated.
    Earl
  6. BlkWlf1968
    BlkWlf1968 Member
    Arlington,Tx
    1973 Maverick 2dr
    The ones I get are from Auto Zone (Mc/Norris) Forgot the #..But are for a 75 ford maverick with power steering...sometimes they ask sometimes they don't...I will check on the # and try to get it soon...
  7. Earl Branham
    Lugoff, SC
    BlkWlf1968; thanks, it will be much appreciated.
    Earl
  8. Mavaholic
    I believe Moog part numbers are K8036, 4 bolt and K8142 are the 3 bolt.
  9. Earl Branham
    Lugoff, SC
    Mavaholic; thanks, maybe now I can get the right ball joints in the car.
    Earl
  10. Mavaholic
    That is from memory so check it before you take them home. I replaced about a Gazillion of them back in the 70's when I was a front end mechanic for Goodyear so I'm pretty sure they're right.
