Upper control arms
Discussion in 'Parts Interchange' started by Relivin1970, Oct 11, 2014.
  1. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    1970 maverick,1972 Sprint
    I just got a set of disk brakes from a 1975 maverick to go on my 69.5 maverick but I noticed that my upper ball joints on the 69.5 have rivets and not bolts like the 75 did ? Should I swap the upper control arm on the 69.5 to the 75 ones as well what about the lower control arm ? I hope someone can help me out thanks guys
  2. dyent
    dyent Member
    vancouver bc
    Rivets are what originally came with our vehicles, bolts means someone has replaced the ball joints at some point and if they wear out again, can easily be replaced. Suggest you take both sets to a good alignment shop to have them check for play/wear and then use the best set for your conversion.
  3. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    Hey thanks my father inlaw just told me the same thing lol I checked on the web and it looks like the control arms are the same for both years so I would think the ball joints will be the same as well. Thanks guys
  4. rthomas771
    Early Mavericks have 4-bolt ball joints...after 7/14/69 they have 3-bolts
  5. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    Mine are the three bolt
