Urethane Tranny Mount
Discussion in 'Parts Interchange' started by CometGT1974, Jan 14, 2004.
  1. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Just thought I'd let you guys/gals know. Prothane make a polyurethane tranny mount for the 65-73 mustangs. This mount will fit our cars, I put one on my car last night and it fits great!!
    At $25 from summit, I think it's hard to go wrong!!
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Yep!
    I put mine on last summer. Its a ton better than the ole rubber things!
  3. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Why is it better?
  4. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I think its because......
    Its a stronger material for better wear and less movement under stress.
  5. jpollard
    jpollard Member
    Montana
    I guess I can see getting one for racing. I have never had one fail on me and for daily driving wont the factory one cause less vibration to the body?
  6. CometGT1974
    Western NC
    74 Comet GT
    I got mine for safety sake. Had someone loose a driveshaft and it ripped the tranny mount in half and ended up cracking his bellhousing and tranny case. These have lapped over metal on the inside so the mount can't be ripped apart.
  7. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    The fellow who did all my chassis work on my car suggested the polyuro. I am running plates. They(plates) "will" allow alot more drivetrain travel than running motor mounts. He said that the polyuro would "limit" that travel, but would not restrict it.
    I beleive you want a travel or "give" in your driveline to prevent breakage.
    That is the same tranny mount they run in their 4.20 outlaw 10.5 car.
    I agree with Stephen, its good and cheap insurance.
  8. CometGT1974
    Western NC
    74 Comet GT
    Hey John, aren't those motor plates connected directly to the frame??
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Yes they are, but its only 1/4 maybe 3/16 inch aluminum. it does have alot of flex front to back.
    If you just set the motor in there without the tranny and stuff, bolt the plates down, you can actually push the motor front to back about a inch or so. Now, you CANNOT move it side to side. The plates in that direction are about 1 foot thick.
    My nephews big block chassis car uses the same size plates(thickness).
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
