wanting v8 302 w/ 4bbl carburetor
Discussion in 'Parts Interchange' started by Xandor16, Nov 26, 2006.
  1. Xandor16
    Xandor16 Member
    Murfreesboro, TN
    I'm looking for a v8 302 in any condition as long as it's whole. I would like for it to come with a 4bbl carburetor or atleast the manifold for one. As I said I am looking for any condition, I want one to rebuild myself.
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Gee, that's not asking for much.
  3. Xandor16
    Xandor16 Member
    Murfreesboro, TN
    I know it's a long shot, I'm also trying junk yards and stuff. Just seeing if any one might have an old one they stripped out and are willing to sell it. If it makes a difference I have a 1970 Maverick.
  4. blue76maverick
    blue76maverick Member
    east tenn. GO VOLS!!
    76 2 door
    i have one in a 76 maverick that im thinking of swaping with efi. it's a 4 barrel with weilend intake and c-4 trans. their are a couple of "issues" with the motor. but if interested let me know.
  5. T.L.
    T.L. Banned
    Southern Colorado
    There ya go. It's your lucky day...
  6. Xandor16
    Xandor16 Member
    Murfreesboro, TN
    :) It's always worth a shot. Worst that can happen is no one has one.
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Wish you were closer...
    I have a roller block, D0 351w heads, aluminum intake...
    Would all need going through.
    Even got a running Holley...
  8. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    1973 Ford Maverick Grabber ginger & white factory 302 c-4 car LDO package
    check the local engine rebuilder blocks are usually 50-100 bucks cleaned machine work can run a few hundred bucks
    cranks about the same price make sure you get the correct imbalance (28.2 or 50oz) and matching rods and pistons balancer and flywheel (thanks ford)
    heads.. sky is the limit how much money do you have and don't count out aftermarket iron heads vrs stock ones price for price. be surprised it might be cheaper or the same price
    tin and front covers are specific to chassis design you buy
    a late model 302/351 it will have the wrong oil pan for early chassis cars like ours
    valve covers are what fits the valve train
    front covers are for where the dipstick and fuel pump are located are dependant on if you are running a mechanical fuel pump or a electric pump.
    as for a 4 bbl intake and carb since this will be your first engine
    I would scour the local engine builders/wrecking yards/hi pro shops might come across a deal swap meets and forums like this are also good places to look
    I would go a performer type intake (edelbrock/holley/offenhauser/etc) and a 600cfm vacuum secondary carb a model 1850 (4150 version preferred over a 4160 econo carb if you have a 4160 it's a easy conversion)
    then your next engine you can do something wilder.. work up to a faster car.. walking from a 15second stocker with a intake and headers to a 12 second terror like mine requires a little getting used to so don't expect to go fast out of the box.. learn to drive don't let the car drive you
  9. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    adapter
    the other day i saw an adapter to install a 4bbl carb on a 2bbl intake, it looked like it could get the job done without the need to change the intake manifold, is this true? are there any consecuences? is this the easy way to have a 4bbl carb on our cars?
    by the way the engine is not a 302 it's a 289:burnout:
  10. Bryant
    the carb adaptor is not a good way to go. its very restrictive and will most likely have less power than the 4bbl did.
  11. maverick75
    The carb adapter probably cost as much as a decent used intake. Out here performers go for twenty bucks. Or you can get an intake from an 80 mustangs. They seem to be plentifull around here also, as most guys go for the EFI stuff.
