Water pump pulleys, do they all interchange?
Discussion in 'Parts Interchange' started by ford84stepside, Feb 21, 2009.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Do all Ford's share the same 4 bolt pattern on the water pump pulleys? The one I was running came off of a 200 6 cyl. Something moved--engine or the electric fan--and a collision happened, warping my wp pulley. I have located another one, but it doesn't have a part number on it. The guy says it came off of a Falcon or Econoline van 6 cyl, unknown size. The diameter and depth sound about like my old one, but I'm unsure about the bolt pattern. Anybody know if they are all the same size bolt pattern?
  2. ford84stepside
    Berry Alabama
    I guess nobody else knows either....:huh:
  3. Thack
    Thack vision advicator
    Moreno Valley Ca
    Most do but I have run into some that have a smaller diameter pattern
  4. ford84stepside
    Berry Alabama
    Thanks, Thack. I went ahead and bid on it. It came off of a falcon 6 cyl, so it should be a 170 or 200 I think, and the one I have now came off of a 200 in a Comet, so it hopefully will work. If not, back to eBay it goes...
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    If it doesn't fit, I have one (somewhere).
  6. ford84stepside
    Berry Alabama
    Thanks Matt. Will know in a few hours if I get it or not. Only reason I was using a 6 cyl pulley was it was the only one that was small enough diameter that I found, and my crank pulley came off of a 73 Mav 302! Ford parts can be confusing sometimes!
  7. Jamie Miles
    I've got a 200 water pump pulley you can have for the price of shipping if the ebay deal doesn't go through.
    and FWIW, a 250 water pump pulley is different then the 170/200 pulley. The bolt pattern is the same, but the pulley itself has a larger diameter.
    When we swapped the 302 into Garrett's (koopstamaverick) '69.5, we reused the water pump pulley off his 170 as well.
  8. ford84stepside
    Berry Alabama
    Jamie, you have a PM
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I know for a fact that there are at least two sizes. I have several around here also if you need one. Most of mine are off of small blocks though.
    I'll do what I can to help
    clint
  10. ford84stepside
    Berry Alabama
    Thanks Clint. I was able with a BFH to massage mine back to health. One of the holes was wallowed out a bit, but the others were ok, so I went with it. I ended up removing the electric fan and putting on a 5 blade Ford flex fan. For now, it seems to be cooling fine without a shroud, when I put the AC back on I may have to go with one of the Taurus electric fans...
