What About This Console?
Discussion in 'Parts Interchange' started by Mel Moeller, Jan 4, 2015.
  1. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    I picked up this console recently and was going to use it in my 71 Maverick when I install my T5 five speed. ( I need to restore the console first) . I have not even cleaned it yet. My question is: What is missing in the front vacant area of the console below the warning lights and where can I get console parts? It needs a new chrome trim bezel and what ever is missing in that hole.
    Do you guys think a 5 speed will work in this console? The console came out of a 76 Granada.
  2. Red1972Grabber
    Northern California
    I have the same console in my car, but it came out of a '77 Versailles. I don't think there is anywhere to get parts, you just have to work with what you've got. I don't believe anything goes in that hole except a piece of carpet. I think it's just to hold your goodies. I was thinking about removing the dummy lights, blocking off that hole and putting a small set of gauges in there.
    I have no idea if the 5-speed will fit, but if it doesn't you can sell the console for around $250.
  3. Mel Moeller
    Twin Falls Idaho
    The Granada was the Ghia version. They are the same. Thanks for the advice. I think removing the warning lights and installing gauges is a good way to go- even fuel gauge there also and then a tach in the dash.
  4. mav1970
    That is a nice console - Mercury Monarch also had a Ghia version - actually my 9 inch disc brake rear came out of a Granada Ghia
  5. Mel Moeller
    Twin Falls Idaho
    Thanks Bob. It needs a little work.
  6. mav1970
    Doesn't everything? :huh:
    Even if your 5 speed shifter doesn't land squarely into the center of the existing shifter hole, I would just be prepared to remove all of the wood grained area completely, fit the 5 speed shifter and then cut a new piece out of some other material that is also wood grain - no problems - just solutions :whew:
  7. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    two tone interior.jpg I my consol came out of a Versialles and I am running a T-5, I think it fits and looks pretty good. I removed the warning lights and installed my gauges in their place.
    I used aluminum for the gauge bezel and the shifter bezel.
  8. Mel Moeller
    Twin Falls Idaho
    That looks really great! I was thinking about selling mine but, I believe I will keep it and use it.
    Did you upholster the armrest. Mine does not look like yours. Mine has a seam down the middle from the factory but I am going to recover it.
  9. mav1970
    Very nice fit indeed - did you dye it or were you really lucky it matches that well?
  10. fastfords
    fastfords Member
    East Tennessee
    Thanks,
    Mel,
    this one came from a versailles and I assume that they all came with the leather covering on the lid.
    Mav1970,
    It is the original color, but I did dye it once because it was alittle dirty and dull.
    Thanks, Chuck
  11. Mel Moeller
    Twin Falls Idaho
    Ah-ha, I will use your picture then as a template to recover mine. Thanks so much Chuck
  12. Mel Moeller
    Twin Falls Idaho
    Chuck- Was your dash that nice or did you do something to it?
  13. fastfords
    fastfords Member
    East Tennessee
    The metal portion of the dash is original, the dash pad was dyed because it was brown and it is cracked. I added the white face gauges and the rear defog.
  14. Red1972Grabber
    Northern California
    I didn't notice the seam down the middle of yours at first. Mine looks just like fastfords does. The Versailles was the high end vehicle that's why they had the lids all covered in "leather". I'm going to dye mine black.
