What route do hoses take to heater control valve 74 302 with ac please????
Discussion in 'Technical' started by murphsmav, Aug 25, 2014.
  1. murphsmav
    murphsmav Member
    NSW Australia
    1974 Maverick 302 C4 2dr
    Hi. New member looking for information on the hose setup and routes for the heater control valve of a 74 302 with ac car. The old valve was bypassed but I have a nos one to replace. The hoses are currently routed from water pump and back to manifold. Pictures would be great otherwise a description would be great too! Im guessing three hoses and I think I know which direction to what outlet but want to be sure. The hose you see joined in the pic under the valve is the only hose in op. From engine back to engine and not attached to heater valve or core. Thanks in advance. Scott.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    My 75 is a bit different valve but, it comes from the heater core - to the valve - to the water pump. The other hose from the heater core goes to an elbow on the intake manifold just behind the thermostat housing.
  3. Craig Selvey
    See if this helps.
  4. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
  5. murphsmav
    murphsmav Member
    NSW Australia
    Hey, great photo. Exactly what I was after. Thanks!!!!
  6. murphsmav
    murphsmav Member
    NSW Australia
    Thanks mate. Appreciate you taking the time to reply. Gives me an idea. Cheers.
  7. murphsmav
    murphsmav Member
    NSW Australia
  8. murphsmav
    murphsmav Member
    NSW Australia
    Ahhh yeess! Amazing on two fronts. I did it correctly as per your photo before my post as a guess (educated not) and I didn't break anything. My wife is impressed!
