What's making this noise?
Discussion in 'Technical' started by Charlie57, Jul 12, 2022.
  1. Charlie57
    Charlie57 Member
    Lebanon, TN
    1970 Maverick, 1957 Chevy, 1989 F150, 1932 Chevy, 1978 VW Bus
    Today my Maverick started making this noise. I have driving the car for about 100 miles since I bought it last month and this is a brand new sound. I have a cheap automotive stethoscope but nothing seemed obvious. Any guesses?
    Thanks,
    Charlie
    https://youtube.com/shorts/LCqJlynyvsY?feature=share
  2. BruceS
    BruceS Member
    Texas
    1973 Comet
    Vacuum leak. Take about a 2 foot piece of heater hose. Place one end up to your ear and move other end around engine to pinpoint the leak.
    71gold likes this.
  3. mojo
    I think a vac leak would cause rough idle; video seems idle adversely affected.
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Can't tell from the audio if it's a really bad vacuum leak or a metal on metal squeal. Can you narrow it down to part of the engine? High/low/front/rear?
  5. Charlie57
    Charlie57 Member
    Lebanon, TN
    A buddy of mine said to spray some brake cleaner around the engine, and if there is a vacuum leak, the engine's rpm should change. I did that and it almost killed the engine when I sprayed the base of the carburetor. The float was stuck open recently so I purchased a rebuild kit and should get it this week. I hope that fixes it.
