Window regulator differences
Discussion in 'General Maverick/Comet' started by Cemeyer, Feb 23, 2021.
  1. Cemeyer
    Cemeyer Member
    Colorado
    75 Maverick Grabber
    What are the difference between 70-74 window regulators and the later ones?
    I found a electric window kit for 70-74 and was curious if there is a way to use it on my 75.
    Thanks,
    Curt
  2. 71gold
    the difference may be the crash bar in the door.
  3. rthomas771
    The holes in the glass for the glass retainer rivets are different location, The lift channel is different, regulator bolt pattern to mount the regulator to the door is different location and the metal texture on the later doors are different.
  4. Cemeyer
    Cemeyer Member
    Colorado
    75 Maverick Grabber
    Thanks!
    Does anyone have a pic showing the differences?
    I’m tempted to order the nu-relics kit to see if I can make it work.
  5. 71gold
    this is nu-relics in my 72 door...it has the window crank switches.
    :thumbs2:
  6. rthomas771
    The blue door is the early regulator. Notice the support arm bolt location in the corner of the opening compared to the support arm bolt in the middle of the opening on the late black door. By looking at the photos now...it looks like the late door is drilled to accept the early regulator, but I'm not saying it will swap, just saying "might" swap out.
  7. Craig Selvey
    The early regulator bolted in to the door. The later regulator was riveted in.
  8. Cemeyer
    Cemeyer Member
    Colorado
    75 Maverick Grabber
    I have an early regulator coming. I'll let you all know the differences.
  9. rthomas771
    I think this is a '75 door...if I remember correctly. The '77 door came with smooth metal finish on the inside were the 70-76 came with a texture stamped metal finish.
    Craig Selvey likes this.
