i've heard that 4-door mavericks are 6-inches wider in the cabin then 2-doors is that true? if not i know of a 4-door with a good windsheild cuz mine is cracked
If you are the one to remove the windshield, don't try it without cutting the weatherstripping. Use a utility knife to cut a piece of the weatherstripping about 3/8" wide all the way around and the glass will lift out. Try to remove the windshield without cutting and you might break it.
