Column to Floor shift swap completed!
Discussion in 'Technical' started by dmhines, Jul 22, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Finally got around to installing my floor shifter today ...
    Entire project took 2 hours and 45 minutes thanks to Ed's ingenius conversion bracket! See here: http://mmb.maverick.to/showthread.php?t=16669
    I don't have any early pictures of me lining up the riser and cutting the hole because my camera batteries were charging ... But basically the riser only really fits a specific section of the hump so its pretty easy to figure out where it goes .... used a hole saw and a sawsall to cut through the floor.
    All I have left to do is smooth out the steering column. I also found out that the pointer on the shift handle is missing so I have to get one of those too ..
    Here are some pics ...
  2. Jamie Miles
    Alto, GA
    I've had a few
    Look good Dan! :thumbs2:
  3. maverick75
    very nice(y)
    i was planning to do the conversion on my 75 to get headers in there but i dont want to go trought all the hassle so i can live w/manifolds right now
  4. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Dan, nice mod!!! :thumbs2:
  5. NICK DOMINICK
    Burke, Virginia
    Looks great!! Let us know how long it takes to shift the car without grabbing air where the old shifter used to be first.
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Nice work Dan
  7. dmhines
    Cumming, GA
    The little shift indicator that bolts to the lever is the same as a Mustang. I guess it is supposed to be clear with red markings? Not sure ...
    Anyway ... nobody reproduces these things and nobody appears to have an NOS one either. If anybody has a trashed shifter they aren't using with the correct little indicator that bolts onto the lever I sure could use it .... Thanks ....
    The part # is C9ZZ-7a110-A if anyone has access to a stash of NOS parts ...
  8. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    That looks really nice Dan,, nice job.
    Dan
  9. maverick1970
    Missouri
    Dan any idea which years of Mustangs and Cougars would have used them?
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    As usual, great work, D!
  11. dmhines
    Cumming, GA
    69 - 73 Mustangs ..... Thanks for the compliments guys ... I like look of the stock floor shifter so I waited patiently until I found a complete setup ... Notice that it came out of a Vomit Green car! :)
  12. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    dan, thanks for the compliment.ingenius, i thought i was just being lazy:huh: .i did not want to take apart the transmission.glad it worked for you. i just took a shifter out of a 76 mustang looks real close to that, i will check the part numbers. i'm also needing the same part i will let you know if it works.
  13. dmhines
    Cumming, GA
    Thanks Ed ... did you get the PM? It looks like there is not supposed to be a bushing on the lever from all the pictures I have seen ... strange Ford didn't put a bushing there ...
  14. fan2488
    fan2488 Member
    spring,TX
    got your pm. thanks
  15. maverick1970
    Missouri
    Dan I will look to see if I have a spare
