If it is a 302, or 6 cyl. mechanical parts will likely interchange. Someone here was asking about a Torino console for a Comet/Maverick. Suspension is all different. Sport mirrors on a Torino I am sure are different at the base, but may work. Rear view mirror should work. Seats? Probably to big but not sure. Rear end is wider, too wide. Wheels will work. Nothing else should fit. Floor shifter can be swapped. Tranny maybe depending on the size of it-C4 yes, C6 not without tunnel mods if you want headers. Seth
thank you seth, i took the seatbelts,rearview mirror,window crank handles,lock from glove box. thats all for now. the torino is the base model with a rubber mat insted of carpet. i cut the belts and i couldn't turn the v8. the way they put it. the trunk is hanging over the bank and i wanted to check the trunk but fear of dying took over.
