8" or 9"
Discussion in 'Parts Interchange' started by AERDAVID, Nov 27, 2011.
  1. don graham
    57 Fairlanes did not have an 8.8 stock. They weren't even out then. They came out in 1986. 57 Fords had a 9". I doubt 9" gears will fit an 8.8.
  2. TJC47
    TJC47 Member
    INDPLS, IN
    FORMER OWNER 72 COMET G.T., 03 Mercury Marauder, 64 Ford Fairlane.
    I'm sorry Mr. Graham I met to say that it was the 8.75"(8 3/4") not the 8.8 intergal. The nine inch rear end and assembly was not used in Ford cars until 1961 and then only in the HiPo cars. The nine inch became standard in the fullsize Ford cars in 1962. 1957 to 1961 used a 8 3/4" ring and pinion, however the 57 and up housing would accept the nine inch carrier. The 9 inch was used in Ford Trucks from 1959 and up.
  3. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    Did the smaller geared carriers require and shop worh to accept the 9" gears?
  4. TJC47
    TJC47 Member
    INDPLS, IN
    Not the 8.75" it should bolt right in the 9" housing.
